Reach RS+ and Reach RS2 are the field-ready RTK receivers used for surveying, mapping, and navigation.
10 km
60 km
20 km
100 km
1-2 min
5 sec
Single-
band
Multi-
band
14 Hz
20 Hz*
*coming with a software update,
up to 10 Hz now
145 x 145 x 85 mm
126 x 126 x 142 mm
690 g
-20…+65º C
-20…+65º C
IP67 (water and dust)
Up to 30 hrs
16 hrs as 3.5G RTK rover, 22 hrs logging
LiFePO4 9600 mAh, 3.2 V
LiFePO4 6400 mAh, 6.4 V
6–40 V
6–40 V
Micro-USB 5 V
USB Type-C 5 V, 2 A
FCC, CE
FCC, CE
H: 5 mm + 1 ppm
V: 10 mm + 2 ppm
H: 4 mm + 0.5 ppm
V: 8 mm + 1 ppm
H: 7 mm + 1 ppm
V: 14 mm + 2 ppm
H: 5 mm + 0.5 ppm
V: 10 mm + 1 ppm
H: 7 mm + 1 ppm
V: 14 mm + 2 ppm
H: 7 mm + 1 ppm
V: 14 mm + 2 ppm
~1-2 minutes
~5 seconds
Frequency range
868/915 MHz
868/915 MHz
Power
0.1 W
0.1 W
Distance
Up to 8 km
Up to 8 km
Regions
Global
Bands
Quad-band, 850/1900, 900/1800 MHz
SIM card
Nano-SIM
802.11b/g/n
802.11b/g/n
4.0/2.1 EDR
4.0/2.1 EDR
RS-232, Micro-USB
RS-232, USB Type-C
NTRIP, VRS, RTCM3
NTRIP, VRS, RTCM3
NMEA, LLH/XYZ
NMEA, LLH/XYZ
RINEX with events
with update rate up to 14 Hz
RINEX with events
with update rate up to 10 Hz
8 GB
450+ days of logging at 1 Hz
16 GB
160+ days of logging at 1 Hz
GPS/QZSS L1
GLONASS G1
BeiDou B1
Galileo E1, SBAS
GPS/QZSS L1C/A, L2C
GLONASS L1OF, L2OF
BeiDou B1I, B2I
Galileo E1-B/C, E5b
72
184
14 Hz GPS / 5 Hz GNSS
10 Hz GPS / 5 Hz GNSS
9DOF
9DOF
Email us at info@emlid.com or fill in a contact form. We normally reply within one workday. However, in most cases, you will hear from us in a few hours.
